Guys,
Just when you think you know your Husky Stuff, things throw you a curve. I wanted to swap the
rear wheel on my 83 250CR with the one from my 83 XC 250. Well the XC wheel will bolt up to the
CR , but the CR wheel don't fit on the XC ?? The braking backing plate cause the wheel to lock
up & barely turns when you tighten the axle nut? Both bikes are all stock & have the original spacers
brake assemblies & the linkages.
I looked up the p/n's for both wheel hubs in the 83 & 84 parts lists & found that the wheel hub are different? Also found a 86 WR wheel will bolt up correctly using different left sides spacers??
I have to get the Micrometer & measure the hub depth etc, but boy that surprised the crap out of me
Husky John
Husky John
